07-26-2026 05:55 PM
Hello helpers, I am looking to join Public Mobile. Can you guys help me with the best deal? Looking for a plan around $20, unlimited calling in Canada, no need for international calling, 10gb data will be enough. Thanks.
07-28-2026 03:32 PM - edited 07-28-2026 03:33 PM
$19 for 3GB is the best I have seen at Public so far. Canadawide calling. 100 international minutes.
It could be a oldtimers plan now but I have it.
10GB should be around $25.
07-26-2026 06:21 PM
hi @Jenil6885 if your budget is $20, check Koodo, they still have $19 plan.
07-26-2026 06:09 PM
At the present time, Public mobile is offering $28/30 days for Unlimited Canada with 10 GB data.
It seems like that Public mobile is offering more attractive plans at higher price points. Trying to get customers wanting US and Mexico roaming and larger data plan.
07-26-2026 06:03 PM
@Jenil6885 wrote:The plans are the ones I am not looking for. Again, my budget is $20. Is there anything in that?
$22 is the cheapest plan. $24 is next.
07-26-2026 06:03 PM - edited 07-26-2026 06:07 PM
Looks like the cheapest start at about $22. Unlimited Canada wide calling, Unlimited international messaging and a bit of no data.
ed...if you must have 10 GB's data...that plan is $28 plus tax,
07-26-2026 06:02 PM
Nobody can tell you what is best for YOU. Every person is different with different needs.
Look at available plans and choose which one best suits you.
07-26-2026 06:02 PM
07-26-2026 06:01 PM
07-26-2026 05:59 PM
just download the Public Mobile app to your cell; create a new account; buy an esim (or get a hard sim before starting activation)....look over the menu of plans and I know you'll find once within your prerequisite. You can either take a new number to initiate transfer of existing number to Public Mobile (just don't cancel your old service first)
07-26-2026 05:58 PM - edited 07-26-2026 06:02 PM
@Jenil6885 wrote:Hello helpers, I am looking to join Public Mobile. Can you guys help me with the best deal? Looking for a plan around $20, unlimited calling in Canada, no need for international calling, 10gb data will be enough. Thanks.
Hello @Jenil6885
Here is where you find plans. https://www.publicmobile.ca/en/plans
And here is a helpful link when just joining.
EDIT: If you are to pick the lowest plan in the plan section, just know this. If you pick very low, after you join, there will be a list of other plans on file for you by opening the app and going to Change Subscription. Currently there is a $28 plan for 10GB of data. On the app, it's only $25 for 10GB of data. So if you pick the cheapest, you can then move up to the $25. However, just make sure you choose "Change at Renewal" so you don't lose anything you paid for today. Then, the next 30 cycle you'll get $25 10GB of data. Does this make sense??
