Locked sim card
DougHay
I had to replace my phone so I moved the sim card to the new phone and it tells me that it is locked. I don't know how to resolve this.
@DougHay
It sure sounds like it is locked or it is not compatible with PM.
What is the make and model of your new phone?
You can return it for a refund if it is locked or not compatible.
@DougHay
is there someone close by with a cellphone you could try your sim in their cellphone ?
DougHay
Was purchased brand new from Amazon as an unlocked phone.
@DougHay  Is this brand new phone or new to you ? If used new phone you will need to ask the carrier it came from to unlock it for you . If it’s just a SIM PUK support can help
send  a  private message   To CS_Agent
hairbag1
@DougHay
could be your new cell is locked to previous provider. Try the sim in your old phone or a different unlocked phone.
