12-03-2024 12:22 PM
Hi
My phone # is now my husbands. How do I switch it back to mine?
My phone was stolen. So I have a new phone and I got a new sim card. All my data is on the phone but it is his phone#.
12-03-2024 01:05 PM
@Gennyredman Yes if you cannot log into your account , just use the link in my last reply to submit ticket with them
12-03-2024 01:03 PM
Can Public mobile change my number?
12-03-2024 12:36 PM
@Gennyredman You got new physical SIM card ? If you can log into your account you can sim swap the number in profile page
SIM SWAPPING profile tabs
This can be done on the app too , but if you can’t log into your account you can get support to sim swap the number for you
