a week ago
- last edited
a week ago
computergeek541
Has anybody experienced bad wifi connection when switing to public mobile? I have never had an issue on my phone when at home until I switched to public mobile. Not happy.
a week ago - last edited a week ago
@NathanPardy - Not me, it could be your DNS Settings on wifi (Change to 1.1.1.1 OR 8.8.8.8) I get 500 on TELUS Fiber before and still the same. Maybe ISP device going down?
I get 250mbps with Public Mobile
If you are talking about phone speeds, here are max speeds that I seen
Roaming Speeds:
a week ago
hi @NathanPardy
if you really meant home Wi-Fi and not mobile data then it has nothing to do with Public Mobile.
you can try to disable your mobile data on your phone and try Wi-Fi again
a week ago
Are you connected to home wifi or are you referring to the data connection?
Try resetting the Network setting on your phone.
No. The two should not be related.
Try resetting your network connection (click circle with wrench icon) or rebooting your phone and your wifi router.
