05-26-2023 02:45 PM
My u20GB data plan just ended so I decided to purchase the 150GB 3 month plan. As soon as I renewed it deducted 22GB from the 150GB. What the **bleep**? I purchased the plan less than 30 minutes ago and I have 127/150GB. You took the amount of data I used last month and deducted it from my **bleep**ing new plan.
my account is gaijd@live.ca
05-26-2023 04:31 PM - edited 05-26-2023 07:34 PM
You are posting to a community of all customers. Ask for help here...complain to a CS rep.
05-26-2023 03:28 PM
05-26-2023 03:28 PM
05-26-2023 03:27 PM
I tried resetting network settings. Only get the option for LTE, no 5g. iPhone 13 Pro.
05-26-2023 03:20 PM
HI @GaijDelaneu for the data used, it's only one glitch and PM could fix
on your iPhone, please reset your data statistics first. In case you have unusual usage, you can check the usage screen and confirm
go to Settings > Cellular or Settings > Mobile Data, and tap Reset Statistics.
For your 5G issue, first change the Network mode to Automatic or 5G first.
If that does not work, try to click Reset All networks.
and best to test the sim in another phone as well
05-26-2023 03:17 PM
I am also unable to access 5G via my iPhone 13 Pro. What a joke of a service
05-26-2023 03:08 PM
**bleep** this bull**bleep** I will be requesting the whole plan be refunded.
05-26-2023 03:05 PM
hI @GaijDelaneu let us know what PM says. There are different glitches these week since the My Account upgrade
05-26-2023 03:04 PM
I tried incognito. same thing. Submitting a ticket now.
05-26-2023 02:48 PM
HI@GaijDelaneu relax, likely just a broswer cache problem.
Please login My Account again using Incognito/Private/Secret mode, you should see the proper usage there
if it is still wrong, check with agent and they can fix it
please submit ticket to CS agent at: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
