Is new $39 20gb per month plan permanently?is available for old point program customer?
K_GL
If yes,old point and add on transferred to new plan ?
12 REPLIES 12
DoubleDeuce
Thanks for the reply!  What I meant though is, will I keep the 3x Points promo that I had before when I switch to the $39/20GB plan?
@DoubleDeuce   it is available now!! Go to Plan change page on My Account and schedule a plan change
DoubleDeuce
I had the same question - anyone know the answer?
Kwammi
I have the 3x Points promo. Will that go away if I change to this plan?
K_GL
you will automatically renew the new plan you selected on your next renew date even promotion was done.
jor123
Does anyone know if you future date a plan change to the end of your billing cycle you get to keep that plan if the promo happens to end before that date?
liuxinbing
I was on 3G/3Gb/$30; just changed to 4G/20Gb/$39 minutes ago. Will see what's happening two days later which is my renewal day.
kaytus
@BKNS27
Thanks...Just try to upgrade to $39-20GB plan
@kaytus
Prices and plans constantly changes so not forever.
Just like the new announcements on 5G and eSIM.
Wait until 2025 when 3G will be discontinued on the cellular network. People will be scrambling to get rid of their old non-compatible phones and getting a new phone.
kaytus
@BKNS27
so the plan is not forever, right? Just wondering
@K_GL
Price of plans may change anytime.
You will continue on the old Rewards system as long as you DON’T click to switch to the new Points system.
Dunkman
@K_GL
Yes, available to existing customers.  Old rewards system will be transferred over, including any existing add ons.
