Unable to activate my eSIM
AnnaPom
I’m unable to activate my eSIM. I get a message that my phone is not eSIM compatible. I already purchased a physical SIM card and had it inserted. Still unable to activate my subscription.
slusagm
PM can help.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here
hi @AnnaPom
you will need support agent to change the sim type from esim to physical and enter the sim card number.   You can submit  ticket by direct message:
Chalupa_Batman
Hello @AnnaPom
Sounds like you deactivated your physical SIM card. And since your phone can't do eSIM, you may need a new SIM card.
Contact a CS Agent to confirm this. And if they say you need a new SIM card, the go with these options as PM sending it can take up to 4 weeks in the mail.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
