01-26-2025 02:08 PM
My account deactivated after the credit card expired. Trying to get a new subscription and it tells me my SIM is already in use. How do I proceed ?
01-26-2025 05:13 PM
Is your account suspended or deactivated? Did the account go without active service for more than 90 days?
If yes then you need a brand new sim card to activate with a new account.
If you are unsure try calling 611 from your phone with your current sim card or 1 855 4PUBLIC from another phone and enter your 10 digit phone #. If they can't find your account it's deactivated. If you get your account info then pay and reactivate your account t.
01-26-2025 02:26 PM
hi @Kenzie1
sim card cannot be reused for another new activation
fastest is to buy a new Public Mobile sim card from Telus or Koodo stores around for $10
cheapest is to get it from Amazon for $5
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
and don't buy online from PM as it could take long to deliver
of course, you can also use esim if your phone has esim
01-26-2025 02:18 PM
@Kenzie1 wrote:My account deactivated after the credit card expired. Trying to get a new subscription and it tells me my SIM is already in use. How do I proceed ?
Not sure why my comment went to the unmonitored section as there was some solid info there. You need a new SIM card to start an account. SIM cards are 1 time use only.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
01-26-2025 02:12 PM - edited 01-26-2025 02:14 PM
Hello @Kenzie1
SIM cards are a 1 time use only. You have to either purchase a new SIM card or eSIM for your phone if it's compatible.
Now, depending on when your subscription expired, you have 89 days to get the same account/plan/phone number if you want. You just need to log into your account and update your credit card. Or if there is a better plan out there than your other one and you don't care about your previous phone number, that would be a way to go. Just know you will need a new SIM card.
