eSIM activation failed
sologarlic
my eSIM activation failed. I logged out and tried again and second time it says my number is invalid. I tried "Get Help" where the system either loops around or send me to a landing page that never finish loading. Where CAN I GET SOME HELP??????
I have already paid and get no help with activate, install eSIM and transferring the number. This is terrible.
1 REPLY 1
hi @sologarlic
ask PM support agent to help.  Submit an Expert Messaging ticket (Please use the same Community login you are using now.  If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account):   https://expert-messaging.publicmobile.ca/guest/chat/
          At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again.  Then login to open ticket
Support agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
