03-23-2022 06:08 PM
It is really difficult to remember to reset the statistic every month. Is there a way to make it do it automatically?
I assumed that ios would access my data plan to determine the "current period", but it doesn't so the period last forever.
03-24-2022 12:04 AM
I was happy with the app called “Data Flow” on my iPhone 6S Plus. Had it on my wife’s iPhone 6S Plus as well but since she got an iPhone 8 hand me down, I have not been able to add that app to her phone yet it still working on mine. So I guess I too am in the market for a new app for Iona one that will do a 30 day plan.
AE_Collector
03-23-2022 07:16 PM
DataMan is free along with...
Check out the above data tracker apps for iPhone.
03-23-2022 07:05 PM
@darlicious you know I am more Android than iOS
Like @hTideGnow , I always suggest My Data Manager. But I see my friends using DataMan Next, or DataMan , except it is not free, I think
03-23-2022 06:46 PM
So that app won't work for the OP. There is one for iPhone that members recommend but I don't remember the name? Maybe @softech knows the app I am referring to?
03-23-2022 06:43 PM
03-23-2022 06:36 PM
Thanks....I couldn't remember if data witness was the Android or iPhone version or both?
03-23-2022 06:25 PM
Try this app.
03-23-2022 06:21 PM
HI@aegerita My Data Manager, try it, it's good, automatic reset for 30 days cycle
03-23-2022 06:20 PM
@darlicious wrote:You can install an app to track usage on a 30 day basis.
Do you have an example or any suggestion of this type of app 👀
03-23-2022 06:18 PM
Unfortunately iPhone requires you to reset your data usage every 30 days manually as it only accumulates data usage on an ongoing basis. You can install an app to track usage on a 30 day basis.
03-23-2022 06:15 PM - edited 03-23-2022 06:18 PM
Yes you can.
Automatic reset...no
Manually at the start of each 30 period
Settings, cellular, scroll to bottom, tap reset statistics
Cellular data "Current Period" and "Current Roaming" Period will reset to 0 bytes
Current "call time" period will reset to 0 minutes.
