11-11-2023 03:22 PM
every hour I get disconnected or get dropouts while it stays connected, or it’s slow, like 5 seconds to load a picture, or sites don’t load and then start again. I’m constantly turning off and on cellular data on the phone and restarting hotspot. Internet sharing through computer wifi also doesn’t work anymore!. It will show the wifi and then disappear. I’ve reset network settings like 10 times. It’s so unreliable and the issues so varied, I can’t even attempt to try to fix one issue where you could say ok that’s a technical issue on my end. It’s as if hotspot is meant for one time emergencies, and not to be able to somewhat provide consistent internet. And these are all Apple devices that generally work together easily.
i was trying to use my 50gb plan to replace home internet as it saves me $50 per month. Honestly 25mbps is fast enough. But the last 6 weeks have been hell, and unless I can fix this, I will cancel this plan and go back to real home internet.
11-12-2023 09:20 AM
Public mobile does not limit hotspot, It should be the device issue.
11-11-2023 08:50 PM - edited 11-12-2023 11:31 AM
change the device settings so that the display never turns off. this will avoid the device from sleeping and disconnecting the mobile adapter. instead of using the USB try creating a wifi hotspot instead. I've had no disconnect issues using that method. Android phone though. if you would like even better reception you can purchase a cellphone booster from Amazon. you will need to do some research on which bands you will need to help boost your data connection
11-11-2023 05:26 PM
All that is in order yes
11-11-2023 05:25 PM
I’m having issues creating a wifi through internet sharing using hotspot through USB source. Not using actual wifi.
11-11-2023 03:32 PM
@Pbubbs If you're having problems on wifi as well as cellular then I would agree with softech that it seems to indicate a device problem
11-11-2023 03:29 PM
@Pbubbs First, PM does not limit hotspot usage, so, it is a device issue
Make sure your Carrier profile is updated
Try Reset All network and test again. Make sure you are not using any VPN (disable or delete those VPN profile). Make sure you are not using power save or data save mode
11-11-2023 03:23 PM
There are so many things that can factor into disconnection like location at time of usage, are you moving around the home or business, external interference, your phone.... you just have to figure out what factors into the disconnection.
