Mobile Router
Edmundo
Hi, does anyone know if public mobile supports mobile routers?
I tried PM my sim on a Netgear M6 Pro mobile hotspot but was unable to connect to data.
RadChad
Thank you for posting this!!!
I have a Cudy 5G AX3000 wifi router, and it wasn't working with the APN set in AUTO.  I went into the settings and the only thing I changed was the APN to manual, and APN:  sp.mb.com.   Boom.  Everything works now.  Very happy.
hi @Munchking PM sim is fully compatible with mobile routers that have compatible bands
But router with compatible bands is the tricky part.  Most mobile routers are targeted for small local market , and most you see on Amazon are designed for Asia and hence people have trouble getting them works
Munchking
Ive never tried it before but It seems that Public Mobile may not be able to connect when it comes to using their SIM cards with mobile routers. According to previous discussions, some say there are issues with getting a data connection when using a Public Mobile SIM in a 4G. Check this discussion below; it may help. routers. https://productioncommunity.publicmobile.ca/t5/Get-Support/4g-Router/td-p/1230676
hi @Edmundo
check APN settings
