4g Router
Zead29
Hi,
Does PM (or telus in general) allow us to use our SIM card in a 4g router device?  I've been using the hotspot feature on my phone but it drains the battery fast.  I picked up a 4g router that supported the same bands as public mobile and it reads the SIM fine, tells me my phone number, etc.  However it never gets a connection.  I've done deep diving on the forums and the APN is set right, and I've even changed the DNS server to a oublic mobile one.
At this point I assume it's blocked by the carrier.    Anyone know?
2 REPLIES 2
maurelle
@Zead29 wrote:
Hi,
We have since ported our "data line" away from Public Mobile, but up to last month we have successfully used a PM SIM in a ZTE MF928 for a couple of years. The unit is discontinued now, so if you are looking for a successor, make sure that its bands are compatible with Public Mobile's (most of these units on, say, Amazon are not compatible with NA providers. If I can't check the bands I'm staying away from the product.)
You'll need to manually set the APN on the router web portal. We also used EverSafe's e-mail option to get account access codes for that line.
EB0
@Zead29
It looks like it’s not supported, but I can’t say that for sure.
Sometimes, I used my old unused phone as a hotspot and keep it plugged in.
