Setting up LTE 4G router
GerardMRanger
Bought a KuWfi LTE 4G CPE router with SIM card slot.  Installed my Public Mobile 5G data plan SIM card and I need routing info such as Destination IP, Subnet Mask, etc. For statc routing.
Please provide.
So far, I have 3G/4G ISP as sp.mb.com
Primary DNS Server 000.000.000.000
Secondary DNS Server 000.000.000.000
Is this correct
2 REPLIES 2
will13am
@GerardMRanger , none of the information you listed relate to static IP.  The only thing you really need to input is APN setting.  As for DNS, you can leave the entries blank and default to the Public Mobile DNS.  If DNS over TLS (DoT) or DNS over HTTPS (DoH) options are available, use that.
@GerardMRanger
you have to put some DNS server there. Good ones are 1.1.1.1 or 8.8.8 8
