04-29-2023 11:01 PM - last edited on 04-29-2023 11:04 PM by computergeek541
Hi. I can't make international outgoing calls that have been possible.. Please fix it quickly. Thanks
04-30-2023 07:47 AM - edited 04-30-2023 07:53 AM
@1205bulls are you dialing correctly? Remember to remove the (0) from the city code when you're dialing from an international location like Canada.
For example, when calling a landline number in Seoul that is normally listed as 02-1234-5678, you need to dial it like this from Canada: +82-2-1234-5678.
Same idea for cell phone numbers, don't dial 010, make sure you dial +82-10-xxxx-xxxx.
04-30-2023 02:36 AM
South Korea was on the original 400 minute, the 400 freebie, the 500 freebies and the current 300 minute.
Either 011 or + should work. If an internal area code has a leading zero then don't dial that zero.
04-30-2023 01:46 AM
@1205bulls south Korea should be included if you got the international LD addon. You have it, do you?
And it ever work? you tried to call another S Korean number? how you make the call? did you call like this 011 82 XX-XXX XXXX ?
04-30-2023 12:29 AM
When I make a call, I keep getting a "on the line" tone, but it doesn't seem like it's because the other person is on the phone.
04-30-2023 12:21 AM
SOUTH KOREA
04-29-2023 11:40 PM
then which country you are trying to call?
also, login using Incognito mode to confirm the minutes are correct
04-29-2023 11:23 PM
also...log in on a laptop and you'll see My Account ...look to the right hand side for Add-on Usage ..then click on the little spinner at bottom like this...
It should show how many LD calling minutes you have left. If you don't see any mention of LD, then you've used them up already and need to buy more LD add-on mins.
04-29-2023 11:22 PM
That doesn't answer the question...what country are you trying to call?
04-29-2023 11:17 PM
where are you trying to call ? Someone here can assist you with the correct dialing protocall.
04-29-2023 11:14 PM
My international long distance minutes are sufficient.
04-29-2023 11:10 PM - edited 04-29-2023 11:13 PM
where are you trying to Call ? Here's a list of countries you should be able to call.
Countries included in international long distance include: Australia, Austria, Bangladesh, Brazil, Chile, Colombia, Czech Republic, Denmark, France, Germany, Greece, Iceland, Ireland, Israel, Italy, Japan, South Korea, Malaysia, Mexico, Netherlands, New Zealand, Norway, Peru, Poland, Portugal, Puerto Rico, Romania, Singapore, Spain, Sweden, Thailand, Venezuela. Calls must originate from Canada. Any unused minutes will roll over to your next cycle.
added...
@softechhas provided a few others.
04-29-2023 11:09 PM - edited 04-29-2023 11:10 PM
Which country are you trying to call? Calls can only be made from within Canada to specific countries. For conplete list, please view the Plans page st publicmobile.ca.
04-29-2023 11:08 PM - edited 04-29-2023 11:11 PM
@1205bulls you can only call some countries with the proper add-on purchased and here are the list of LD add-on options.
