12-05-2022 09:35 AM
I put funds on my account and it is still saying suspended!? This happens every month. I then went to my account to see what was going on it said a valid password I've had the same password since I've had this phone for 2 years. I've changed my password 3 times now and it's still saying a valid password. What is going on?? I can't get into my account. I can't go on an agent Ever!!!!
12-05-2022 10:05 AM
@LORI5 but is your service still working? if so, no worry. Yes, the renewal process takes time. Usually the whole process will finish around 6 to 8am EST, but on some odd days, it could be as late as noon time 😞
12-05-2022 10:03 AM
Thank you, it should have renewed at 6am it say, that was 6 hours ago. The correct amount of funds is on it. I've just finished trying the suggestions, nope. Sent a message to an agent with high hopes 😆 thank you!
12-05-2022 10:02 AM
Thank you very much, I've tried all that, I've just sent a message to an agent. Fingers crossed!
12-05-2022 09:59 AM
Is your phone actually working? Did your plan just renew overnight? On the evening of renewal, Public mobile will show various warnings about suspension, etc. AS long as you have enough funds and your phone is working, you can ignore the warnings.
The website is finicky. Try the above suggestions to login into account.
12-05-2022 09:53 AM
@LORI5 it could be just a browser cache issue
can you try again using Incognito mode to login? or using Incognito mode to request the password change and then use Incognito mode to login again
You can also use *611 to load fund and reactivate your service if you know your 4 digits PIN
Just in case you really need PM support to help reset password, here you are:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
