I mistakenly activated my previous number
02-11-2022 07:30 PM
02-11-2022 08:15 PM
If you ported in your phone number changing it in your self serve is not an issue unless you intended to keep that number with your old provider. Porting it out from your previous provider automatically closes that account. If you change your number now that will send your old number back to the original provider you got it from. If that is not an issue for you then just change your number in your self serve account.
If this was a mistake and you need the old number to have remained active elsewhere or its tied to a business or employment or something vital like that then contact customer support before you change anything to see if they can help you save the phone number for the account at another provider.
02-11-2022 08:07 PM
Which number are you referring to? Your SIM number or your phone number?
If it was your SIM number, login to your Self Serve account and click on Change SIM card.
02-11-2022 07:40 PM
@nilisnothing what you meant by you activated previous number? you meant you requested to port your number? If so, depends on what stage, you can "cancel" that. After you request porting, you would have receive a text from your old provider and you are supposed to reply within 90 minutes. If you have not reply yet, DON"T. As long as they didn't get they YES answer your number would not be ported (Unless you are porting from landline, it might be slightly difference with the process, let us know, but you still have time)
Then the next thing you do is to login to My Account and click "Change Phone Number" and then you can picked a new number.
And that are all you need to do if you said "mistakenly activated my previous number" actually meant you requested porting and you changed your mind
02-11-2022 07:34 PM
You can change your phone number up to 4 times every 30 days after you’ve activated.
To change, go to your Self Serve Account Here and:
- Select the “Plans and Add ons” tab
- Click on “Change Phone Number”
- Then, you can choose to select a new phone number
- and Rebooting device.
02-11-2022 07:34 PM
What do you mean - you activated previous number??
Is this new account?
You can easily change your number using PM self-service account. Just click on
Change Number and pick another one. You can do it 4 times per 30 days.
