RCS messaging “waiting for activation”
shae6969
I had an iPhone 12 with successful access to RCS messaging.
I just got a new iPhone 16 and tried to transfer everything over to my new phone. I have managed to get SMS messages and calls directed to my new phone but I am unable to activate the RCS messaging - it gives me a “waiting for activation” message.
What do I need to do to get this activated on my new phone. I know that it worked with my previous phone that was older so I’m assuming a newer version should also have access to this capability.
I downloaded a new e-sim to transfer everything over. Is this not available through e-sim or do I need a physical sim number like I had in my old phone? When I try to change the sim number in my public mobile it says that that sim number is already in use.
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
hi @shae6969
usually better to disable RCS BEFORE porting but it is too late now
 If you don't disable it before porting, then it takes a while for the RCS system to update that the old Carrier has released your number before the New one can enable it.
Now, just turn it off for a couple days, and try again. Then it should work. It took my friend 3 - 5 days for his to work. it is an Apple problem not PM.
shae6969
We have reset the settings and restarted the phone several times
hi @shae6969 sometimes it just time and it needs patience
make sure they new iPhone has latest iOS and Carrier Profile
Turn off that RCS toggle first , then Reboot phone and Reset Network Settings and try turning RCS on again and wait and  check again
