01-28-2025
06:53 PM
01-28-2025
07:15 PM
computergeek541
My partner and I bought two chips and were porting our numbers from 7-11 Speakout to Public. I went first, created an account, payed the subscription fee, activated it, and then used the tool in My Account to transfer to my previous number. The transfer was almost instantaneous and I was impressed, however when it was my partner's turn to do the exact same process, after finishing it and waiting, it seemed the transfer did not happen, even though the transfered number is listed on the app. Eventually (around 1h30min later) she received a message on her 7-11 SIM (that is still working normally) saying:
"Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect account number. Someone from our team will contact you shortly using your original phone number or the alternate number you provided. You can also get in touch via our virtual assistant at: [link]"
But no one called! She can't even login into her account on here because the login code is being sent to her first number with public mobile (the one that was supposed to have been replaced) but she doesn't receive the messages.
I am writing here as I have attempted to resolve the issue through the chatbot but we can't get far without her having access to her account. I have read somewhere else in the forum there is a phone number we can call to resolve number transfer issues, but I have had a hard time finding it on the site. Please help!
01-28-2025 07:28 PM - edited 01-28-2025 07:33 PM
Is there any service on your wife's Public Mobile sim card? It sounds like there is if you logged into her account to request porting. If that's the case then she can login by clicking on "Didn't get the code?" and choosing email instead.
With the above scenario you can re-initate porting by calling the porting department with the number provided in your private messages by (@Yummy) @hTideGnow and supply them with the preferred porting info that they request from you.
If there is no service on the Public Mobile sim card you need to contact customer support first before you submit the new port request.
Edit: Sorry @Yummy but I cant seem to tag you?
01-28-2025 07:20 PM
Problem with IMEI is Speakout only keep the IMEI when the service was activated. If people changed phone, Speakout won't update to the new one, and they won't tell you what IMEI on their record
all these I got from :
https://productioncommunity.publicmobile.ca/t5/Get-Support/Porting-number-from-Speakout-Apply-also-t...
01-28-2025 07:18 PM - edited 01-28-2025 07:20 PM
I hope you used a different email address for your partner’s account because you can only use 1 email/1 account. So you can’t use the same email for both accounts.
If you did, contact a CS_Agent to change the email address on your partner’s account.
01-28-2025 07:16 PM - edited 01-28-2025 07:18 PM
@slusagm wrote:with 711 Speakout, porting is via "PIN only" as it does not have account number. you will need to call the porting team and provide them with PIN
I wouldn't suggest the PIN. Many do not realize the difference between account PIN, voicemail password, phone PIN, network unlock code, etc. IMEI should be used. PIN is really the last choice, and some carriers/some customer service members at some carriers will even refuse to submit a porting request if the customer tries to only provide account PIN.
01-28-2025 07:12 PM
01-28-2025 07:02 PM
hi @Dani7
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
01-28-2025 06:59 PM
Nobody from PM is going to call you.
I sent you porting support phone# (talk to LIVE people).
01-28-2025 06:59 PM
@Dani7 Try messaging using this link to send a private message to the cs_agent. They should be able to dig in further than the chat bot. Best of luck, Hope this helps.
