Public Community Points
rolandlafleur
I heard that you can earn 20 points per month just by chatting in the community and asking questions. Do the points vary or can every earn 20 and how will you know? I just want to know more details
7 REPLIES 7
RavingRaven
@rolandlafleur
Generally community points are awarded by how much you post and how many bravos and solutions are earned on those posts relative to how many are also earned by your fellow members.
If you are keen to learn more about your Public Mobile service and app/account and then also pass on that knowledge to other members when they ask a question you will be able to earn community points.
To get an idea of who earns what each month go to the bravo leaderboard at the bottom of the community landing page and scroll down the leaderboard. If you click on the top 25 or so members and go to their profile page it will show all the badges they have earned. (The ones with dates attached are the actual badges earned by the member.)
If you use the search bar and type in "Top Contributors Announcement" with the month and year previous to about August 2022 those announcements actually included the "shout out" to the names of the members that earned the top 1%, 5%, 10% badges and the then current oracle team. Currently there is on average 25 members included in those 4 levels and another 50 to 75 members combined in the top 25% and 50% levels.
Neil11
It's a lot of work but worth it, I have been getting 1-2points per month. The hard part is getting your answer to be picked as the solution. Also you have check the chat regularly to be one of the first to answer. If you repeat an answer the oracle will remove ur response. Good luck!!!
@rolandlafleur wrote:
Thank you!
How will you know if you’ve earned a point from answering someone’s question or asking a question? Since the max I can earn is 15 points.
Asking questions doesn't earn points.  The Community points are based on helping others.
We don't really know how they calculate it. It's not per question,  but it's added up for the 30 days in the month and at the end of each month your provided with the points.
So the January results will be posted around February 7-8.
Here is December's.  You will always find it on the Announcements page at the time I indicated.
https://productioncommunity.publicmobile.ca/t5/Announcements/Top-Contributors-December-2024/td-p/129...
rolandlafleur
Thank you!
ORNGNBLK
@rolandlafleur   Community points are awarded for participation on this forum. If you provide answers to questions, solutions to problems etc you will receive "bravos" from other users. These bravos accumulate and can result in rewards ranging from 2 pts to 20 pts per month. 20 pts are reserved for Oracles but 2,5 and 10 are definitely achievable.  The more you participate, the more you can earn... Hope this helps
Sansan
@rolandlafleur  technically as a member it the maximum you will earn is 15 points per month; 20 points is reserved for specific set of individuals called Oracles.
You will probably earn 1 point for a few months, then move to 2.... Points are earned by asking valid questions like you did and answering them.
It's a LOT of work. It takes time and effort. Probably not worth your time for 1 points, but you keep it up and each point add up.
Around the 7-8 day of the following month everyone will get there earnings posted in their account. You sign into My Account, and there is  a section called Rewards, you will see Give Back.
