07-29-2023
03:01 PM
07-29-2023
03:08 PM
computergeek541
I purchased an eSIM for travelling overseas and I can't install it. I confirmed before buying the esim that where there were no SIM Restrictions in my iphone settings but it appears that Public Mobile does not support Dual SIMs on their service? Is that correct or is there something else I'm supposed to to. When I try to scan the QR code for the eSIM or try to Add Cellular Plan in the settings ... that option is not there. Apple support says I need to contact Public Mobile to assist. Is there anything you can do to help?!!
thank you
07-29-2023 04:25 PM
@Handy1 ... haha
07-29-2023 04:22 PM
@KWYD Or sept just around the corner iPhone 15s for the whole fam 🙂
07-29-2023 04:21 PM - edited 07-29-2023 04:34 PM
Ah yes, that'll be the problem. The iPhone X does not have esim capability. Your daughter can get a physical sim once abroad. Just take the PM sim out temporarily.
07-29-2023 04:19 PM
@softech and @DennyCrane .... my sincere apologies ... I just figured out the problem. My daughters phone is in fact "just" and iphone X ... and not an iphone XS like the other 3. .. Argh!!
07-29-2023 04:08 PM
@softech ... yes ... I could either just scan the QR code to activate or go into the settings to Add Celluar Plan. I suspected there was an issue with my daughters phone because it wouldn't scan the QR code. Then when I went into the Settings to add it that way there was no option to even add another plan
07-29-2023 04:07 PM
As I've said, PM does not restrict the year of a third party esim.
07-29-2023 04:05 PM
@KWYD did you use eSIM in your other devices?
07-29-2023 04:02 PM
Sorry ... I don't know how to tell if it is physical or esim. All the other iphone XS devices support dual sim and esim and I had not issues installing the Orange eSIM for travelling. Is it possible that certain PM plans don't support dual SIM? My daughters plan is one of the lowest plans.
07-29-2023 03:55 PM
Ah, so she has an iPhone XS. You've stated different things in different posts. In that case the device has single esim capabilities. So you should be able to run 1 physical sim and 1 esim. Again I'll ask, is her Public Mobile line on a physical sim or an e-sim?
07-29-2023 03:53 PM
@DennyCane ... iphone Xs is
07-29-2023 03:53 PM
@DennyCrane I agree with you iPhone X won’t support eSIM just the iPhone XS and later . OP said 4 XS devices or s was there for plural
07-29-2023 03:51 PM
According to this the iPhone X isn't esim capable. This may not be completely accurate though.
https://www.makeuseof.com/which-iphone-models-support-dual-sim/
Is her PM sim a physical sim or an e-sim? Even some esim capable devices can only support a single esim, not dual.
07-29-2023 03:47 PM
I have 4 iphone Xs devices ... they all have dual SIM support ... and they all support eSIMs ... and all of them except this one (on PM) will allow me to add an Orange eSIM. This one (for whatevery reason) does not show that I can even add another Cellular Plan. I know ... it does not make sense ... hence why I'm here asking the question.
07-29-2023 03:46 PM
I was reading something about iphone the other day and saw something about dual sims/esims. Not all iphones can. So which exact model of iphone do you have?
07-29-2023 03:41 PM
see if this is helpful
https://www.airalo.com/help/using-managing-esims/how-can-i-remove-an-esim-from-my-device
Again, do Not delete it or you will have to go back to physical sim with PM. PM will probably fix this problem soon, but not at this moment
07-29-2023 03:39 PM
Go into your sim card settings and turn it off. Do you actually have an e-sim capable device? What phone model is it?
07-29-2023 03:38 PM
@softech ... how do you disable it without deleting it?
07-29-2023 03:37 PM
@KWYD your iPhone has ESIM?
07-29-2023 03:36 PM
Hmmm ... then something else is wrong. This phone is for my daughter on PM ... The same Orange esim works with my iphone (different provider from PM)
07-29-2023 03:35 PM
The inability to install an e-sim from Orange mobile has zero to do with PM. You need to contact Orange and/or your device manufacturer.
07-29-2023 03:34 PM
Thanks CharlieWhisky ... already purchased from Orange ... just can't install it
07-29-2023 03:33 PM
@KWYD this is not something PM is blocking you.
You might want to complete the travel eSIM activation while you are in France. You can disable the PM eSIM but do not delete it (you won't get PM eSIM back if you delete it)
07-29-2023 03:33 PM
Handy1 ... it is a prepaid from France but I can't add an additional eSIM (so it looks like dual esim is not supported by PM?)
07-29-2023 03:30 PM
Correct softech ... the eSIM is with Orange in France
07-29-2023 03:18 PM - edited 07-29-2023 03:19 PM
It sounds like you purchased a travel esim from a different provider than Public Mobile. If you're having trouble installing it, you need to contact the provider of that esim.
PM does not restrict dual esim functionality. I have that very setup on my phone and have no issues (physical PM sim and Ubigi travel esim). You can also do dual esim, however esim is dependent on your actual device.
07-29-2023 03:16 PM - edited 07-29-2023 03:17 PM
You should investigate Airalo esim for travelling.
07-29-2023 03:04 PM - edited 07-29-2023 03:04 PM
@KWYD Check your welcome email from PM on computer for thenQR code and scan it with your phone and install it . As for over seas PM only works in Canada and the US with US roaming . So anywheres else in the world . Your best to get a local pre paid sim in your destination
07-29-2023 03:03 PM
you said you purchased the " eSIM for travelling", is that eSIM you cannot install a PM eSIM or eSIM with another provider?
AFAIK, there is no restrictions with dual eSIM support with PM.
