06-21-2024
04:03 PM
06-21-2024
04:19 PM
computergeek541
I’m travelling to the US from Canada and purchased the US roam add on. Now I’m wondering if I can call back into Canada with this plan or can I only call and text within the US?
06-21-2024 06:22 PM
Hello @jodiiyoung99
Depending on what plan you have, if you do a lot of US traveling, you may wish to consider the $34 Can/US plan. This way you don't need to purchase addons and can talk text and use data like you were in Canada.
If you have just a regular Canadian plan, you need to purchase one of these addons.
As you can see, the first two is what you'd be interested in. The first one comes with 3GB of data. The second one is just talk and text. You can use both of these addons to contact back to Canada while you're in the US. Hope this helps.
06-21-2024 04:18 PM
@jodiiyoung99 wrote:I’m travelling to the US from Canada and purchased the US roam add on. Now I’m wondering if I can call back into Canada with this plan or can I only call and text within the US?
This depends on which add-on was purcahsed. Not all raaming add-ons include phone calls.
06-21-2024 04:07 PM
yes, you can call back and text back to Canada from US with the US roam addon
