07-29-2023 03:27 PM
Long story short, I googled whether or not my new phone was Esim compatible instead of using Public Mobile's option to check.
I purchased an Esim plan, but can't activate my account because my phone turns out to not be Esim compatible as the information I got was incorrect.
I really don't care about getting the money back - I just don't want to have to create a new email address just so I can stay with Public Mobile.
But because I can't activate my account, I'm unable to login to do anything else including changing my plan type.
(This is a different account associated with an old email address that's been hacked, so it's the only reason I'm able to post this message).
Help?
07-29-2023 03:48 PM
@Cormerdamus don't activate again of PM already chanrged you earlier. As said above, open ticket with support and they will arrange the change sim for you
07-29-2023 03:47 PM - edited 07-29-2023 03:48 PM
@Cormerdamus Please submit ticket with support to help assist in this case . And have them swap the SIM card number for you . And finish the activation
privrate message To CS_Agents click
VVVVV Link below VVVVV
07-29-2023 03:46 PM
I've already purchased the physical SIM, I can't activate it because my account itself is stuck on wanting to activate the E-SIM plan I've already purchased.
If I attempt to log in at all, it asks me to finish activating the E-SIM plan, then tells me my phone isn't E-SIM Compatible and sends me back to the log in screen again.
The purchase has already come off my credit card too - so it's just stuck there in Limbo.
07-29-2023 03:31 PM
@Cormerdamus You can get a physical SIM card and activate it .
07-29-2023 03:30 PM
did you activate yet and PM charged you?
if so, no worry, you just need to get a physical PM sim from Telus or Koodo stores and message support to help to change sim for you to complete the activation
