I'm part of the old rewards system, if I change my plan now do I still retain my earned $ off/month?
Mechecor
Hello
I am considering swapping my plan to the Black Friday promo.
I noticed the promo says it earns $XX points per month.
If I change my subscription to this, do I still maintain my old rewards program (where it's $ off per month), where I get $ off my monthly bill based on loyalty + referrals?
Thanks
ztraz
I have the same question, I'm on the original reward system and I'm currently saving $14 per month on the 3G $25 plan. If I switch to this new $34 per month plan will I only be charged $20 per month ($34 - $14 = $20)?
Meow
You will retain your old rewards as they are tied to your account and not to a plan!
HI @Mechecor
no worries, you will stay on the old rewards system. Change plan won't affect that.
The points there is only marketing tone for new accounts
mojorising
You will not lose your rewards. That message is for new customer subscribers.
