I have a plan with 3G data, but when I turn data on it says LTE and doesn't work.
AUserHasNoName
I just switch to Public Mobile, I put the settings in for my data, its been a week since I switched and now instead of saying 3G it says LTE and no longer gives internet access. I was previously with Virgin Mobile, my phone is an LG G4.
13 REPLIES 13
@AUserHasNoName
You may want to contact moderator to see whether they can help.
Have you tried your SIM card in another phone?  Probably still an issue with the setting on your phone since your data now works, but it is possible that it is Public Mobile service issue.
Send a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
AUserHasNoName
MMS still not working.
@AUserHasNoName
I checked this website for your phone APN setting
https://apn-canada.gishan.net/en/apn/public-mobile/lg-g4
I did notice one difference:
 MMS Proxy: 74.49.0.18
Not sure whether that will make the difference.
@AUserHasNoName wrote:
Added that, MMS still is not working.
RE: APN type, RobertQc included the following in his list:
If you were able to edit in default,mms...what about these other options?
AUserHasNoName
After a factory reset it has not fully resolved the issue, data works for apps and internet browsing but not MMS.
AUserHasNoName
@AUserHasNoName, can you edit your APN settings? If not, can you add another one?
Your APN type is wrong. You need to add at least the following:
default,mms
AUserHasNoName
It does say that I have 4.5GB Data on my plan, my data worked for a day or two after switching. MMS does not work, some apps do work and others are really slow or don't work. There are no restrictions in my settings turned on. My APN settings do not show everything you listed, I have APN settings as follows:
APN: sp.mb.com
Proxy: 74.49.0.18
Port: (Blank)
Username: (Blank)
Password: (Blank)
Server: (Blank)
MMSC: http://aliasdirect.net/proxy/mb/mmsc
MMS Proxy: (Blank)
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: (Blank)
APN type: (Blank)
APN protocol: (greyed out and IPv4)
APN roaming protocol: (greyed out and IPv4)
that is all the APN settings available.
AUserHasNoName
Everything else works fine, and my data worked fine for the first day or two after switching.
mimmo
Before factory reset try network setting reset.
If you show LTE that should mean I think you are getting data network
Does the data add-on appear in self serve?
Luddite
@AUserHasNoName Try a factory reset; LG's have been reluctant converts to the PM network. https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/LG-G4-not-connected-to-cellular-data/...
Dunkman
@AUserHasNoName
Did your data ever work?  Or just recently stopped working?  Is everything else working ie. text and talk in/out?
RobertQc
3G is actually 4G / LTE but the speed is throttled so regardless if you have a 3G plan or LTE plan the network icon will be the same unless you go into network settings and select the 3G network operator
Turn air plane mode ON then OFF. Do you have another phone to try your sim card in to see if data is working? Has data every been working? Have you tried data on more than 1 app, have you confirmed you have no local data restrictions / firewall settings? Go into mobile data usage under settings and make sure you have not used your local "data limit" and there are no network restrictions
Go into network search and try reconnecting to the network and make sure LTE is set to preferred (even if you have 3g)
Does MMS work? (Not SMS) MMS uses data
Make sure your data plan is active in self serve and shows under "My Data & Add-ons"
The first thing to check is your APN. It is the most common problem regarding data not working.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
