I have 2 PM phone numbers, one with $15 another with $40 plan. Can I request to interchange numbers?
VK
I have 2 PM phone numbers, one with $15 having more rewards and another with $40 plan with less rewards.
13 REPLIES 13
dabr
@VK    As mentioned a few times already, why not just change plans (Change at Next Renewal recommended) for both accounts instead?  Achieves the result you want...
VK
Checked with CS_Agent and they clarified that "Phone numbers cannot be interchanged between accounts"
venigab
Is there a way to close my community account so none will mess up with it again? Thx
venigab
Really confused. Kept receiving emails from PM community and was wondering what's going on?
Somebody was messing up with my account I guess. Just changed my password to a new one sophisticated this time. OMG.
chukdefatey
@venigab So you know this can be done? Other Veterans poster have correctly answered OP question
@venigab wrote:
Yes you can. The 2 accounts are yours. Send a request to CS. Good luck.
Sorry, but this isn't correct.  Others have already correctly answered that customer support agents wouldn't be able to assist.
venigab
darlicious
@VK
I'm not understanding why you just don't change plans? Is one account on points and the other $$ rewards?
ShawnC13
My question is  why don't you just switch your $15 plan to the $40 and the 40 down to the $15. You don't need moderator help that way.
VK
@softech & @Hollister Thanks guys..
I will check once with CS before making a final a decision.
kaytus
@VK i wish i can do it, but sorry it doesn't work that way
@VK   sorry, swapping number is no longer allowed
In your case, both $15 and $40 plans are still available, why don't you just pick the new plan on both accounts?  or you are planning to port out one number?
Hollister
@VK
No, you cannot swap numbers between accounts.
