I dont have 5G, although I subcribed 5G plan
NghiQuan
Hi everyone
I Subcribed 5G plan 34$ for 50gb, My phone is Iphone 14 pro max, I dont understand why my esim dont get 5G.  In my setting-> Cellular->Voice&Data I only see 3G and LTE. I tried to delete esim and active new esim but samething. Before I use Public Mobile, I have plan with Telus and I had 5G on my phone
Update by Softech: removed screenshot for privacy
17 REPLIES 17
fixin1
@Rastin - Yes, the phone number is unnecessary for us to see and for spam callers claiming that they work at Public Mobile. @NghiQuan click the upside down " ^ " and click "Edit Post" and remove that image.
Rastin
You should remove the image with your phone number on it this is a public forum anyone can see it
fixin1
@NghiQuan - You may be able to update to 16.7 with little to no slowdowns.\
EDIT: You cannot update to 16.7 anymore unless you are on iPhone 8 / X. The only signed IPA's are 17.4.1 now. And you will keep your phone's apps running good.
HI @NghiQuan
you have an iPhone 14 , new enough that you might actually see speed improvement out of it
and a lot of the time, it is the app that slowing the overall phone and not the OS.  So, no worries, go ahead and update it
NghiQuan
I believe new ios will make Iphone slowly
hi @NghiQuan
what is the issue with iOS update?  it is always better to have the latest one for new features, and more importanlty, security fixes
NghiQuan
so How I can update the Carrier profile. I will try this first if i still dont get 5G I will update my IOS. I really dont want update my IOS.
HI @NghiQuan
you really need the latest iOS to see the 5G option.  Telus has 5G before Public Mobile, so the older iOS might be the reason
But you can first update the Carrier profile and see if it works.  If not, you need iOS update
This is unrelated to your specific plan.  All Public Mobile plans give access to the 5G network.
@NghiQuan  Your IOS should be updated to 17.4.1
NghiQuan
Can I update Carrier without update IOS, i dont want update IOS. Because I had 5G with Telus before
@NghiQuan don't stay with older iOS.  An iOS upgrade would trigger the carrier profile update as well and will unhide the 5G option
NghiQuan
How I can update Carrier profile? My IOS is 16.1, I believe IOS 16.1 is good enough for 5G. I had 5G before with Telus
fixin1
@NghiQuan - Update your phone in Settings > General > Software Update and update it to 17.4.1
EDIT: iOS 16.5 is the minimum requirement for 5G here since that was around the date that it was released. Also you can only get 17.4.1 and it is working good on a Telus bring it back 14PM if the "Slowdowns by Apple" are worrying you/
NghiQuan
My current IOS version is 16.1, Carrier 52.0. So how i can update Carrier 58.0
HI @NghiQuan
first, even with LTE connected, your download speed will be around 250M, which is the speed promised on the 5G plans
is your iOS up to date?  Also, update the Carrier profile as well
if you still don't see the 5G option, check with PM support as well, they will be able to reprovisioned your account to unhide the 5G option:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
fixin1
@NghiQuan - So a 14 series. Should work.
Please update to the latest software and make sure in Settings > General > About that the SIM version says this: Public Mobile 58.0 as that is the latest update. If it is below that number please update your phone in Software Update.
Also LTE is as fast as 5G.
If you are on 16.5 you may get 5G toggle here but 16.6 and newer is definitely.
