Where do I find the manual eSim info
12-20-2024
08:30 PM
12-20-2024
11:11 PM
computergeek541
Bought an ESIM To try activate additional data plan,.. it canceled my regular sim.
Esim qr code scanner doesn't work on my p40 or p40 pro
Now my phone is useless, I'm out 5$ for Esim, and 10$ for a new sim in 4-10 business days.
Manual entry Esim asks for
SM-DP+ address
Activation code
Confirmation code (optional)
Been back and forth with an agent for 3- 4 hours now.. I don't think they are responding anymore..
Anybody have any advice?
Joining Public
12-20-2024 10:25 PM
again esim doesn't install automatically on either of my devices. p40 and p40 pro, possibly due to no gsm (Huawei)
qr scanner doesn't work either.
cs_agent didnt seem to understand what I was asking, so I tried asking here.
I am looking for the manual esim entry info, maybe it's only my devices that offer this manual option? but I don't see that info on my receipt or in my email.
lol
im not buying another esim.
they do not work in my case, and I'm kind of frustrated that it killed my working sim without a backup/reverse option in the first place.
12-20-2024 10:19 PM
did not work on my p40 or p40 pro, possibly due to not having gsm?
just wanna try the manual entry.
I accidentally clicked solution button but this did not work in my case
12-20-2024 10:17 PM
Hi @Durdens
login using the app and confirm your phone number in the Account page.
if it is correct, then go to Account and buy the esim again and let the app to install the esim for you. Yes, you might need to pay another $5 but esim replacement is free and will be able to get the $5 back from Pm support. You can message them after to ask for reimbrusment
To buy esim again:
12-20-2024 10:07 PM
@Durdens , did you do the e-SIM purchase on the mobile app. The e-SIM should auto install via the app. See help article.
https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
12-20-2024 09:27 PM
yes, now I have no phone service for two weeks, during the holidays at the cost of 15$
esim doesn't work on either of my devices and cs_agent says that ' carrier supplied esim' should be supplied by me. ?
I never got the manual esim info:
SM-DP+ address
Activation code
12-20-2024 08:54 PM
hi @Durdens
you said you activate addtional data plan, so you setup another account ? did you use a different email address? PM system is one email for one account (phone number) . So, it might be what caused the problem
you can ask support agent to help to sort it out
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
