11-21-2024 09:46 AM
As tile says CAN/US /MEX plans have arrived community wow weeee have a look 👀
Black Friday sales shaping up to be the best ever
3 weeks ago
75 gb for 35 $ now good deal
4 weeks ago
@alegator_23 That’s good question , because even thou there’s roaming in MEX there’s no add on for MEX like there is in the U.S. so in the case of you were in the U.S. you would need US roaming data add on I belive . So until public rolls out add in for Mexico I think you would be Outta luck . One might be then better off asking support to help them out with early renewal of the current plan they are on might be best way around that situation should it arise
4 weeks ago
50 GB Can/US/MEX plan, when 50 GB exhausted, i understood that the data will not be throttled and i will loose the data capability and will be required to purchase additional data (Data Addon).
What would be a proper data addon to add in case of 50GB exhausted, especially when abroad ?
Would that be Canada Data Add-Ons - example 200mb for $5 ?
4 weeks ago
@alegator_23 Yes you will get 2FA and SMS will work while roaming in the U.S. and Mexico . And you can call to and from all 3 countries CAN/US /MEX using talk text and data no worries
4 weeks ago
Can someone in Mexico or US, confirm that the Banks SMSes (MFA) are working properly, and the SMS can be received on the phone while roaming in MEX or US on the new 50GB CAD/US/MEX plan ?
Thanks
a month ago
Not sure, but I wouldn't bank on it. It's not needed anyway.
a month ago
thanks @DennyCrane. do you know if there is 2G there?
a month ago
Mexico still has 3G coverage, so lack of VoLTE isn't an issue there.
a month ago
do you know if Mexico still has 3G?
and are you using VoLTE or 3G voice? or even 2G?
a month ago
Yes, in Los Cabos I can see LTE speeds with both TELCEL and AT&T
a month ago
So to confirm the internet speed is fast enough in Mexico (you have mention LTE speeds) ?
Thanks
a month ago
Correct. No roaming charges
a month ago
@Sunman001 Do you mean to say there are no roaming "charges"? The Can/US/Mex plans are roaming plans, and when you use the service in those countries you are roaming.
a month ago
it includes long distance no matter where you are Canada US or Mexico, from and to.
a month ago
Yes, I am in Mexico and there is no roaming with that new 50gig plan
a month ago
I am in Los Cabos, Mecixo and there is AT&T and TELCEL, both work LTE speeds. good reception.
a month ago
What part of Mexico ?
How is the reception in Mexico ? What is the Roaming provider there?
How is the data usage, is mobile data working fast ?
a month ago
+1 is the international country code for both Canada and USA and always has been.
a month ago
i am in Mexico and I lost 4 days trying to figure out how to call OUT from Mexico into Canada..
REMEMBER to dial +1 then the canadian phone number with area code.. because just dialing the number does NOT work, nor does 001+ the number... you will save yourself a ton of grief.. just add +1 at the front.
a month ago
@JimmyO23 wrote:Doesn’t Public select the provider automatically? I know when I used my AT&T in Canada, it would select the best signal.
Yes, of course, but manually choosing the network is a troubleshooting step.
a month ago
12-07-2024 12:25 AM
Just make sure you’re not choosing to roam now with AT&T 😂
12-05-2024 08:06 PM
Awesome! Now I can get rid of the AT&T sim……people could only hear every third word anyway while I was in the States. 🤭🤣🤣
12-05-2024 04:39 PM
It’s incredible the number of people I tell about the new plan that say, “nah, I’m good”.
My pays $55 for 4 gbs. He said, “I don’t need the extra data”. I asked, “can you use the extra $240/year savings?”.
My brother pays $100!! And he said, “you get what you pay for”. 😳🙄
12-05-2024 04:26 PM - edited 12-05-2024 04:28 PM
Correct with new the Can-USA-Mex plans
no roaming fees in Can USA and now MEX
this includes local and long distance calls between these countries and within the countries. So keep that dual slim slot ready for when you travel overseas and further south than Mexico.
12-05-2024 04:18 PM
Are you positive about using it while traveling in the US, Canada and Mexico with NO roaming? It reads that way to me but when you click on the details, the waters get muddy.
I have been using a dual sim phone for years. I use my Public for the people with phones that charge for texts to the US and have an AT&T sim that allows use in Canada, US and Mexico.
12-03-2024 01:40 AM
@DJSSB Ah yes, that's a different issue. There were some plans that included additional long distance minutes to other countries such as China and the UK (in addition to US/Mex). They saw the extra long distance minutes one one screen, but not on the screen where they went to change the plan on.
12-03-2024 01:40 AM
@DennyCrane OOh This LD includes to mobile or landline numbers?
I know many providers are restrictive for one or the other. Ie: charging more for Mobile numbers with Long Distance calls.
Thanks again.
12-03-2024 01:38 AM
Thank you @DennyCrane
Much appreciated,
I wasn’t sure because there was a post about not seeing LD minutes with these BF plans when activating so I was confused.
But that seems to be for a few other countries only.
Cheers.
12-03-2024 01:22 AM
@DJSSB It includes any combination of the above. You can call all 3 countries from any of the 3 countries.
