06-15-2022 10:41 PM
My account got suspended so I tried reactivating, there's enough money in my account it just wont go through, I feel like I've tried everything, I've added a dollar into my account, and I tried suspended my account through lost/stolen phone and reactivating it again, removing my card and adding it again, but nothing has worked, please help. Also when I have tried paying for my plan it says there's already sufficient funds, I just don't know why it won't renew
08-11-2022 01:46 PM
@Pien- I can log in. Can you? Try another browser or device or use incognito mode. How long ago was your last payment?
08-11-2022 01:42 PM
Can u longin
08-11-2022 01:40 PM
Can’t reactivate my plan can’t add funds
08-11-2022 01:38 PM
@Pien- We're now into a new system from this past conversation that you found. What exact problems are you having? Are your services working? Can you log in to your account?
08-11-2022 01:34 PM
I got same problems
06-16-2022 10:33 PM
Telling us the mistake you made would help future readers. Nobody knows who you are so you can't be embarrassed.
06-16-2022 10:23 PM
I'm all good now, I figured out the issue which was a mistake I made, my bad whoops
06-16-2022 09:02 PM
So you see a balance of $15 now? Does your account status possibly say Lost/stolen? If not then click on the reactivate button which will take you to the payment screen. At this point it might reactivate. Check to see if you now have a $0 balance.
Restart your phone and see if any services work.
06-16-2022 08:01 PM
Hi @nicoal how much showing in Available Fund on My Account now?? Check it first
06-16-2022 07:59 PM
I've added the $3 and it's still not working
06-15-2022 11:47 PM
@nicoal wrote:My plan is the $15 one, because of my Rewards I only have to pay $10, and I have $12 in my balance
PM server wants full $15 payment without taking your rewards into account because your account will not earn any reward while it was suspended for 1 month. Add $3 to your account and click the "Reactivate current plan" link to get your phone working ASAP.
06-15-2022 11:28 PM
I suggest putting another $3 in. Your rewards should have already been put in. You need more money.
06-15-2022 11:16 PM
@nicoal Make sure you are clearing the cache/cookies and using incognito/privacy mode or even another fresh browser before trying to reactivate the account.
06-15-2022 11:13 PM
06-15-2022 11:08 PM
What is your balance and what plan are you on? If your balance isn't enough to pay your plan then you need to manually pay. Use the Other option, not Amount due.
06-15-2022 11:07 PM - edited 06-15-2022 11:08 PM
@nicoal You need to first Resume service (from Lost/Stolen option) and then you should see the Reactivate option to reactivate the account.
edit: thanks for updating about Resuming the service.
06-15-2022 11:07 PM
Yes, I've tried the reactivate on the overview page and yes I've resumed service after suspending thought lost/stolen phone
06-15-2022 11:04 PM
Well my plan expired in May 15th, after I tried those things to fix it, I thought if I waited a month maybe it would work but it's still not
06-15-2022 10:54 PM
Your account could be going through the regular renewal process. It will look like plan is Suspended...but as long as you have $$ in Available Funds or a credit card set to Autopay...all will be well in the morning.
Your phone should still be working right now.
06-15-2022 10:51 PM
Is your renewal date tomorrow? If your phone is still working…there will be a standard notice if you are on AutoPay or have sufficient funds to ignore the message and your Account will show Expired or Suspended. No worries.
It will disappear after your renewal date.
06-15-2022 10:48 PM - edited 06-15-2022 10:49 PM
@nicoal Topping up the account or using the lost/stolen trick should have activated the account.
Did you also click the Reactivate option top right of overview page? Might need to do that a couple of times and then log out and reboot the phone.
edit: BTW, you did go back and Resume service if you had Suspended the account via Lost/Stolen Phone?
