07-28-2023 05:14 PM - last edited on 07-29-2023 03:50 AM by computergeek541
07-28-2023 05:40 PM
are you using a new-to-you phone that you recently purchased from someone ? Can you try that sim in a different unlocked phone ?
07-28-2023 05:25 PM
you checked My Account?
and for peace of mind, check if your phone is blacklisted
07-28-2023 05:22 PM
Now it is give me this error message (not registered on network
07-28-2023 05:16 PM
then, it’s likely your plan needs to be renewed.
Log into your self serve account and top up enough funds towards the plan of your choice.
Then reboot your phone, and you should have full services.
07-28-2023 05:16 PM
Did you check if your account status is active? To avoid browser cache confusing, please login My account using Incognito mode to confirm account status
If it shows On Hold (Suspended) , then it is a payment issue. Click "Pay Now and Resume Services" to make a manual payment
If it shows active,
if nothing works, message support here
07-28-2023 05:16 PM - edited 07-28-2023 05:17 PM
@Ahmed2003 Can you log into your account or dial *611 is account active or on hold. ? Have you tried rebooting the phone ?. When’s the last time you made payment ?
adding also check
Outage map in your area: @Ahmed2003
