Purchased wrong add on by mistake
HockeyDad
Can I switch add to correct one or get a refund accidentally bought us roaming when needed to buy extra data
2 REPLIES 2
Zanerz
I hope this works our for you friend ❤️
@HockeyDad  If this just happened . By accident submit ticket with support and explain that . And hopefully they can reverse it for you
private message   To CS_Agents click
adding also note that data add ons now expiry 30 days after purchase . And that there’s a 20GB $39 plan right now that will never expire . @HockeyDad
