06-26-2026
12:39 PM
- last edited
a month ago
Dunkman
06-26-2026 01:21 PM
Do you have Roaming enabled in your cellular settings. Adding to other members comments about VoLTE. You may need to manual connect to AT&T, T-Mobile or Verizon.
06-26-2026 12:45 PM - edited 06-26-2026 12:46 PM
to keep in contact with fam back home, you can talk and text using WhatsApp for free, uses your PM data or local wifi. Download the free Whatsapp and have fam do likewise.
ed
06-26-2026 12:42 PM
hi @Jmack77
it could be because your phone is not on PM's VoLTE whitelist. US has no more 3G network, and if your phone is not on the VoLTE list, you won't be able to use the voice in US. Use the IMEI checker to confirm
https://www.publicmobile.ca/get-help/articles/volte
06-26-2026 12:41 PM
should be the right add-on to call most any Cdn or US number. Could be a VoLTE issue...here's some reading with a device checker at the bottom...
