2 weeks ago
Hi. I bought the add-on for USA talk and data. The data is working fine but I can't make any calls.
2 weeks ago
happy it helps.
Enjoy your trip, @Mirela3 !
2 weeks ago
Connecting to T-Mobile worked. Thank you!
2 weeks ago
hi @Mirela3
what phone do you have ? which network you are connected to now?
try to change the network to T-Mobile, connect it manually and test
if you still cannot make the call, change the network mode to 2G when you are still on T-Mobile and try again
