Are we able to use public Mobil in the states?
CC11111111111
My current plan is $34.99 —— 50G US/Canada roaming. Does it mean I will have access to data when I’m in US ?
and how about phone call?
2 REPLIES 2
CC11111111111
Thank you
TheSterlinger
@CC11111111111  yes you can use your plan in both Canada and the US calls and data. Nothing extra needed.
Can be tricky to get connected sometimes. You have a VoLTE enabled phone?
You woukd need to put your hone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile.
Ensure you turn on data roaming.
Sometimes after doing thus might have to restart phone.
