12-12-2024
12:29 PM
12-12-2024
02:54 PM
computergeek541
Hi All, these are the bandwidths of the Redmi Note 14 Pro +, can it work with Telus on the network?
12-12-2024 12:48 PM
yes you should wait
12-12-2024 12:47 PM
true ,I will need to wait for the Global version then. thanks!
12-12-2024 12:43 PM
Get Canadian approved phone in order to maintain compatibility. Try not to use cheaper Chinese versions.
Minimum recommended phone specs:
3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
4G FDD-LTE: B4 and B12
Telus current LTE bands are (in order of band number):
B2 (1900 MHz or PCS)
B4/B66 (2100 MHz or 1700 MHz or AWS / AWS-1)
B5 (850 MHz or CELLULAR / CLR)
As of March 2021, B5 is no longer available in urban Manitoba (Winnipeg and Brandon)
B7 (2600 MHz or 2500 MHz or BRS)
B12/B17 (700 MHz or MBS)
B13 (700 MHz or MBS)
B29 (700 MHz or MBS), for downlink only (SCC for CA only)
B30 (2300 MHz or WCS), for TELUS only (not shared with Bell at this time)
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
3G/HSPA: 850 MHz, 1900 MHz (UMTS).
12-12-2024 12:32 PM
i won't use that on PM or Telus network, you don't have enough bands on 4G. And you don't have n66 for 5G
and yor phone wont work with VoLTE, so , it needs 3G for voice and we dont know what network band you have on 3G
