2 hours ago - last edited 2 hours ago by computergeek541
40m ago
I have been with PM for 3 years and I’ve only contacted the CS_Agent a couple of times. They got back to me within a hour.
If you want to keep your number. Your account must be active. Your account will automatically cancel if your port your number to another carrier.
2 hours ago
give us some idea why you want to leave Public Mobile. You have yet to post a question or told anyone what the initial problem is other than bad customer service. I would argue you actually got excellent customer service as your question was responded to within minutes of you posting it. Give us a chance to actually help before you leave ticked off.
2 hours ago
@Vasan Bear in mind that if you are switching to another provider you need your Public Mobile account to remain active until the transfer has been done, unless you don't want to keep the same phone number. Once you port out your number to another carrier your Public Mobile account will be deactivated.
2 hours ago
@Vasan wrote:Very bad customer service public mobile i need cencel my acount
Service cancels automatically after your account goes into suspension for 90 days. To let it go in suspension disable autpay in your Public Mobile self serve account. You may wish to also use to chatbot to open a ticket and ask a customer support agent to remove the credit card from your account.
2 hours ago
How to cencel my public mobil service
