After I change to public mobile, I can’t send text messages and I can’t receive any test messages
Jackyzhuang
can you please check, what’s the problem with this issue. It is not my cellphone problem since I changed to second phone to test it as well.
much thanks
jacky
2 REPLIES 2
eddieO
@Jackyzhuang, does calling in/out work? and what about data? Depending on how long it has been since you transferred in your number from an old carrier it's possible that the porting was not quite complete. Try restarting your phone and retest all services (calling/text/data). If still not working reach out to a support agent using the link already provided
ORNGNBLK
In order to get network support send a private message to a CS_Agent using the Link below.  They should be able to restart your network.
Hope this fixes your issue.
