Generated text messages
Belsden
I am not receiving text messages pushed from systems (ie Rogers Yahoo).  Texts sent from contacts are received properly.
Belsden
This is not a new activation.  Receiving calls and contact texts works as expected.  The issue first showed when trying to change my password for Rogers Yahoo e-mail.  The 2 stage authentication sends a text (6 digit code) to my phone but it never arrives.
HI @Belsden
was that a new activation?  How long you joined?  it is normal for the 2FA text to start coming couple days later
@Belsden
First, did you just join PM and  do you receive any incoming calls and regular SMS (P2P) from friends?  If so, it is good, at least the porting was completed successfully
For 2FA text or other system generated text (A2P), it is normal for them to start coming later.   Systems take longer to find out you changed provider and to route the text correctly to the new provider (Public Mobile).    Also, financial institutions (banks) or government agencies (e.g, CRA)  put this delay on purpose too to avoid SIM Fraud
Usually they will start coming around the 3rd day after porting but it could take as many as 7 days for all the 2FA/A2P text to come.
