12-11-2024 08:59 PM
I suddenly lost my mobile network service, unable to make/receive phone calls this evening, but able to receive/ send test messages. I reset my network, now totally lost PM network service.
Can someone help me? Thanks a lot!
12-12-2024 02:08 AM
Did you resolve this issue. I am getting the same problem.
12-11-2024 11:29 PM
PM has removed the mobile data/voice outage alert in Calgary, so it should be fixed. Try reboot the phone
https://www.telus.com/en/ab/outages
or if you still encounter the same, tell PM your service problem. Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
12-11-2024 11:26 PM
Any resolution? I have exactly same issue in Calgary
12-11-2024 09:49 PM
Ok, I’ll try get in touch with agent then. Thank you guys!!!
12-11-2024 09:39 PM
yes, so it won't be APN
try Reset all networks. If not, it is a network problem in your area. you can report that to PM
12-11-2024 09:37 PM
I’m in Ontario. It was working perfectly fine during daytime…
12-11-2024 09:36 PM
follow the APN settings above.
but if you have voice call issue, it is not something APN can fix. APN ony affects data, nothing to do with voice
12-11-2024 09:36 PM
I can receive/send text messages after change MMS port, but still unable to make/receive phone calls.
12-11-2024 09:33 PM
I have “Proxy” and “MMS proxy”, which one I should update? My “Proxy” is Not set, and my “MMS proxy” is 74.49.0.18.
12-11-2024 09:16 PM
are you in Calgary? there is confirmed outage there
12-11-2024 09:12 PM - edited 12-11-2024 09:15 PM
@Amber-26, check your APN settings in your phone's Cellular section.
For more info: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
I would actually try restarting the phone first though or if you have access to another phone to try with your SIM in it
