04-28-2022 11:38 AM
Is there a way to see my credit card info that i saved for Auto-Pay? I am asking because my gf needed to update her expiry date, which we did but want to make sure it is updated with correct info before the next payment date. I try to see that info in my own account but can;t find it anywhere, neither can find the same question in forums.
Payment
05-02-2022 06:02 PM
@aliaksar2000 just use method 2 to send PM direct message then 🙂
05-02-2022 06:01 PM
I resolved the issue by following another thread's suggestion since we got an error when we tried to replace her card and wasn't sure if the expiry date was successfully changed. We entered her CC info one more time by using Replace this card option, this time entered everything in caps-lock and entered her address exactly as it appears in her CC statement (which is missing a dash). Weird that it said 'it was successfully updated'. Wow finally. Thanks everyone for their effort.
05-02-2022 05:59 PM
Thank you for the detailed answer. I tried the number 1 option but then it asked me to create a Community profile (it's for my gf, she isn't tech savvy at all). I need to have her next to me, ask questions, she answers, set up password, verification of password, double verification. I said to myself, I can't go through this. Will do this as last resort. Lol. But thanks anyway.
05-02-2022 05:41 PM
Usually PM will send you a text and asking you to update the expiry date if it needs to be looked into
Unfortunately, there is no support line to call and talk to live person. But you can open ticket with them, they will validate your identity and will help. To open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-02-2022 05:38 PM
It makes sense if there is no place to see it for security purposes. I guess, we will need to call an agent. Because we changed expiry date by clicking on Replace the Card option, actually we entered the CC number, expiry date, address, cvv, all the info it asked, but then it gave an error. That's why we don't know if it changed it or not. Yes there is a payment went through after that but the payment occurred on April, and her old CC's expiry date was April 2021, so it would go trough even if the system didn't change the expiry date. So we still don't know.
04-28-2022 12:04 PM
There is not for security purposes I guess, but if expiry date has just been changed and your card has been on for awhile then you would probably have to update card, if this is your first one or 2 payments and your card already had the updated expiry date, you should be good.
04-28-2022 11:54 AM
If you do not see card details when trying to replace current one, there is no other place. Unless you ask agent to tell you (if they can see it).
Did you have at least one renewal paid so far? If yes, then card is in order, just remember Which card did you use.
04-28-2022 11:49 AM
Follow steps provided above...then click on Replace this credit card to enter new card expiry date.
I don't see any other place that you can "see" your current cc info.
04-28-2022 11:46 AM
There totally should be but no, all you can see are some digits. Not the rest of the details.
04-28-2022 11:41 AM
Thanks for the answer but that's not what I want to do. I already did this but now I want to see my credit card info (more specifically expiry date)
04-28-2022 11:39 AM - edited 04-28-2022 11:40 AM
Log in to your account..click Payment..then scroll down to Manage my card. You can edit cc there.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
