05-02-2022 12:00 PM
- It says it is full but no I need this repaired asap please can only text here or message here.....no email yet
Other
05-02-2022 04:37 PM
@mlucas can you login to My Account and confirm if account status is ACTIVE and the date of the next renewal? Is it May 30? Kindly post a screenshot
Also, please also check My Data & Add-ons section, maybe post a screenshot as well
If you are certain it was paid on May 1, account status showing Active and next renewal date is May 31, and just that they didn't reset the data for you, then you can open a ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-02-2022 04:35 PM
05-02-2022 04:34 PM
I have unlimited calling, and texting, and no my data usage is not used up it re-set May 01st ....if they don't repair or upgrade might go back to another provider
05-02-2022
04:29 PM
05-02-2022
05:26 PM
computergeek541
I have data and got de- activated ??? I want upgrade 22-05-02
05-02-2022 01:06 PM
Sorry to hear this… What type of plan are you on? Are you able to log in to see the data use on your account? Has your phone been activated in the last 24 hours?
05-02-2022 12:26 PM
Did you just port a number over to PM?
05-02-2022 12:09 PM
You say "yet". Are you new? Has data ever worked here? Can you call in and out?
05-02-2022 12:04 PM - edited 05-02-2022 12:04 PM
@mlucas Login to My Account, My Data and Add-ons box, check if you have a line about data like this:
if no such line, that confirms your data is all used up. You will have to buy extra data add-on for use until the next cycle
If you see a line like that, it will tell you how much data you still have. In that case, try to reboot your phone once and see if it works. If still not work, try to change the Preferred network to 3G Only and see if it helps
