How to add Friend?
HI All,
How to add friend in this new Community?  I cannot find my way around to add
thanks
9 REPLIES 9
@darlicious wrote:
Scratch all that. You can friend or ignore a user by clicking on the settings icon for each member
You are correct.
You can actually add friend while being in private mail but future friend has to send you private message first. Even though it says 'added to contacts', friend will show up in 'friend' list.
@hTideGnow
Scratch all that. You can friend or ignore a user by clicking on the settings icon for each member. Click on the settings icon on the left beside the send a new message to manage your contacts and friends. I would have thought someone would have explored these options by now?!!🤔
0PX9O4
With PM, a lot of change is for the worse 🤷🏻‍
Thanks for confirming
So, ignore is gone , too.  I guess that could be a bigger lost than Friend?
darlicious
@hTideGnow
That option no longer exists. Previously there was a setting in private messages allowing you to "friend" or "ignore" each member in their private message or in their profile.
Edit:
I'm not sure if I can find a pic of the other option.
2nd Edit:
Here is where it used to appear in members profiles:
Meow
It looks like PM removed that feature in latest Community update.
I can see my old 'friends' I added before but there is no option to add new.
What for you would use 'friends'?
@0PX9O4 wrote:
I try to look for friends in real life now, so I couldn't tell you how to make friends on here.
Also doesn't help that it looks like they've removed the feature altogether.
HI @0PX9O4  I am trying to find friends to help with  bravo 😂
Serious, I am curious how to add friend in the new layout  (actually, I wonder how to do in the old one, too)
porcupine
i cant find a setting to add a friend
0PX9O4
