01-02-2025
06:25 PM
01-03-2025
01:13 AM
computergeek541
Hi there,
A friend referred me to Public Mobile. I should receive a $10 credit for the referral. I don’t see it on my account. How do I receive it?
Thank you
01-02-2025 11:09 PM
Mine took a few days to show up
01-02-2025 06:45 PM
You'll receive it in 2 to 3 days
01-02-2025 06:33 PM
hi @eddieO the referral credit should appear in your My Account within 72 hours. Make sure your wait 3 days and check
if same, then ask support to check
you can submit by direct message:
01-02-2025 06:27 PM
@Tracy_Res10 please note it can take up to 72hrs to appear in your account. If you have been waiting longer than this then you will need to reach a support agent and ask them to put it in for you.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
