Refer a friend
01-01-2025 03:25 PM
I'm a new customer . my son is already a customer. Can I still get his refer a friend code and reward after I registered and how do I do it
Rewards
01-01-2025 03:29 PM
Thank you!
01-01-2025 03:27 PM
@Nadine4 yes but you will need to message a support agent and let them know that you missed the step, they can then add it back in for you. It typically takes up to 72 hours for the credit to appear in your account.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
01-01-2025 03:27 PM - edited 01-01-2025 03:27 PM
Hello @Nadine4
Yes, of course. Here's how. Send a message using this link. Then below is your mailbox which to where they will reply.
