12-01-2024 07:12 PM
12-02-2024 12:24 PM
Reminder: log into your account and click "Change Subscription". This will show you what plans you are eligible for even without contacting support. Your desired plan might be there already, mine was. This will save you a lot of time, providing you have an existing working plan already.
12-01-2024 08:08 PM
Sorr I’m new at this. Still learning how the community chat works ☺️
12-01-2024 08:07 PM
Oh. No they didn’t. I just sent a ticket
12-01-2024 07:33 PM
@JAM10 Wow so they let you switch to it ? Can you please confirm ?
12-01-2024 07:17 PM
if you're an existing customer, you likely can't get this plan. Best is to log in to your account to view the available plan menu.
12-01-2024 07:17 PM
I would contact a CS Agent and ask them.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
12-01-2024 07:15 PM
@JAM10 You can’t if it’s not in your account to switch to we all have target offers and if your plan is already more then $29 then it’s harder to downgrade only seems to be 20GB $30 plan that most can downgrade to at the moment . Shirt if porting number out and back in on newly created PM account with new sim and new email can you get the desired $29 plan unfortunately
