01-02-2023 07:20 PM
Hello,
I have 2GB giveaway from the holidays, what speed is this data? I currently have a 4G speed plan. Or is the giveaway always 3G speed?
Thanks!
Add-Ons
01-02-2023 07:35 PM
Data add ons are the same speed as your plan's data speed. If you have a plan with no plan data in its features then the data speed defaults to full speed 4G LTE.
01-02-2023 07:28 PM
@gtom it will be 4G speed then
01-02-2023 07:23 PM - edited 01-02-2023 07:24 PM
It’s what ever your on now so In your case it will be 4G
01-02-2023 07:22 PM
hi @gtom ,it will be 4G speed then
01-02-2023 07:21 PM
The speed of the data gift will be the same speed of your plan.
01-02-2023 07:21 PM
Speed is whatever your plan can handle.
