11-23-2024 04:30 PM
Planning to go to USA next month .
In the past, I have purchased the USA talk/text 10/15 day package and it has worked great!
I now noticed that in my "add-on usage', I have an unused "$0 holiday giveaway 400 mi long distance (incl ca and us)"
My question is :: do I still need to purchase the 15 day talk/text package to use my phone in the USA?
or is it covered in the 400 minute giveaway?
I also have a friend who says all I need is to use is Whatsapp ---instead of buying the 15 day package?
I am currently on the $13/month plan and use an iphone 15
Any comments/ideas/suggestions are welcome
Thanks
Add-Ons
11-23-2024 06:31 PM
Unless you need mobile data I would suggest a free app such as WhatsApp or similar. You can call, text and message on wifi without any cost. My relatives travel extensively and they do this so they can always connect with family at no cost.
11-23-2024 05:30 PM
As stated, we are still on the $13 plan.
I think our best bet is to buy the 15 day add-on.
That's probably all we'll need
and ........I can keep my cheap plan when we return!
Thanks
11-23-2024 05:26 PM
Hairbag1
I think the 15 day solution will work out best for us.
Thanks for your time
11-23-2024 05:24 PM
Hey @2Hands
How about thinking outside the box of getting a US addon. With the newest Black Friday deals, why not consider getting one of those instead. That way you never need addons again. Depending on what account you have I guess. Just figure out the difference between the account you have now and what account peeks your interest that US included, x it by 12 and then figure out how many addons you'd buy a year.
11-23-2024 05:17 PM
That's just a long distance add-on to call the US from Canada. You need a roaming add-on or a roaming plan. What plan are you currently on? There are Canada/US plans (that don't require extra roaming) for as little as $29, depending on what plan you currently have.
11-23-2024 05:13 PM
you can use WhatsApp to keep in touch with others who have that app. You'll be needing either wifi or separately purchased data to use WhatsApp. Depending on how long you plan on being in US...probably just as simple to get the 15 Day US roaming add-on that you are familiar with already. There's currently some Canada/US/Mx plans available, but you won't be able to get your $13 plan back again when you return home. For the occasional use...stick with the add-on in my opinion.
11-23-2024 04:35 PM
hi @2Hands you still need roaming add-on, the holiday give a way is a Long distance call from Canada, not roaming
and yes, WhatsApp is good, you can use it wherever you have Wifi
11-23-2024 04:32 PM - edited 11-23-2024 04:33 PM
@2Hands Yes you still need US roaming add on , or CAN/US plan to use in the U.S. . those long distance mins you have are only for making calls from Canada to abroad
