Hi, I've just activated a $25 per month public Mobile plan and I still have no data
SCFurlong
I activated my $25 per month public Mobile plan last night at around 9 a.m. . Before I went to bed, my phone was sending and receiving SMS and I was able to call and take calls. As of 12 p.m. today I am still unable to send MMS messages and I do not have any data. I tried everything that I could find in the community to no avail. I've confirmed on my account that there is 3 GB of data remaining, I've triple checked my APN settings, I've reset my network settings and I restarted my phone more times than I can count. My phone is an LG G4, admittedly old but it used to work on the public mobile network and I'm currently waiting for delivery of my rugged phone.
I recall having the same issue when I initially set up this phone a couple of years ago. At that time, it involved somebody doing something inside the public mobile network and my issue was fixed. I guess I'm looking for that help again.
Thanks in advance
1 ACCEPTED SOLUTION
Accepted Solutions
@SCFurlong
As previously mentioned older LG phones almost always need a factory reset.
49 REPLIES 49
t_p
@SCFurlong
Could you post a screenshot of your overview page?
Edit: Your cell data is not off by accident, right?
@SCFurlong
You can try a network reset but the bad news is you probably have to back up your data and do a factory reset. This is a known issue with LG phones.
darlicious
@SCFurlong
After you successfully factory reset your phone you can edit/add and save the following APN to your phone.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
Everything else works but data...
Any chance to test your SIM in some other phone since you mentioned you had issue with your phone before?
- Change the network to 3G
@SCFurlong
Did a moderator (now a CSA) text you a configuration file? Was it right after you activated? Has your LG 4 been used with a different provider since then?
@SCFurlong   Please do a network reset first.
It is very common for LG phone that need a network fresh after changing to a new network.
If it still does not work, you might also want to Factory reset your phone.  LG is a bit tricky when used on a different network.
@Yummy
Switching to 3G won't fix this as MMS can use either network. This is an APN issue.
@hTideGnow
Is there an echo in here?😃
Since you mentioned this, which phone brand (Android only) is the most trouble free in terms of settings and switching providers?
