10-18-2023 07:27 PM
Just switched to Public today from another carrier and successfully activated on an iPhone XR with eSIM. My subscription gives me 30GB at 5G speed up to 250mbps.
However, I'm getting extremely slow LTE speeds, even slower than 3G (see images below).
I've tried restarting my phone, configuring APN settings, and resetting network settings as per chatbot advice. Any help is appreciated, thanks.
10-19-2023 11:25 AM
How is signal quality affected by using an eSIM vs a physical one? Do you have a source for that? I'm using eSIM btw and get 250mbps on 5g or LTE.
10-19-2023 08:20 AM
For updating carrier profile, try this
10-19-2023 08:02 AM - edited 10-19-2023 08:03 AM
is there a particular reason you decided to use an esim? I would advise against using esim here, there is not enough support and they have a horrible implementation of it. also signal quality on an esim is typically inferior to a physical sim
10-19-2023 02:02 AM
I was never prompted to download any carrier profiles when I installed the eSIM. Where can I get them?
10-19-2023 02:02 AM
Signal is strong, usually 3 or 4 bars. Tried in another nearby location with similar results. I'm on 4G.
10-19-2023 02:01 AM
Will try this, thank you.
10-19-2023 02:01 AM
Thanks for the suggestion. Unfortunately, selecting Automatic vs manually selecting Public Mobile doesn't have any affect on the speeds.
10-19-2023 02:00 AM
Yeah, these tests were run at home but I also tested 9Mbps at a restaurant nearby. Will keep monitoring in other areas but what a bummer. I might have to switch back to my previous carrier who provided a much better service in my area.
10-18-2023 11:40 PM
HI @puddls
do you have the latest Carrier Profiles? Check and update it. Then try Reset network settings, and try in different locations. Also, try with different phones
10-18-2023 10:12 PM
How's your signal? Have you tried in different locations? Are you connected to 5G or 4G? Try both. I prefer 4G even though I have a 5G plan.
10-18-2023 09:47 PM
you can ask customer support to reset the network on their end. include as much info as possible as it is not an instant chat type of communication. tell them about your data speeds and that you would like them to reset the network on their end
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
10-18-2023 07:49 PM
Try this. Can't say it will work but worth a shot.
Go into Settings, Network Selection, turn off automatic and pick Public Mobile. Reboot the phone. Then try a test again. Report back.
10-18-2023 07:39 PM
@puddls wrote:Just switched to Public today from another carrier and successfully activated on an iPhone XR with eSIM. My subscription gives me 30GB at 5G speed up to 250mbps.
Unfortunately, changes to APN settings woudln't help as those simply provide instructions to the device on how to connect to data. There woudln't really much that can be done about these speeds other than to try in a different location. I suspect that the data network is congested where it was tested in your screenshots.
